Memory Card
James41b
I've purchased a Lexar 8Gb memory card and when i format it through the psp it doesn't seem to be working, so i can't put any films on. I've got a fat psp version 2.6. I purchased the card throug a uk website - could it be a faulty card?
Any advice would be welcomed.
Sonic67
Does it say magicgate supported when you query it for information?
How much did you pay? Play has them for £35-£40.
Genuine Memory Stick displays User Capacity 8GB as 7687MB or 7763MB.
twogubs
Your firmware version is too old at 2.6 to support an 8gb card.You will need to upgrade to at least 2.81 and even then there were problems so you should consider going to the most recent updated firmware as Sony implemented changes as they went.
James41b
Thanks for that. Now is this upgrade hard to do? Or can i go straight from Version 2.6 to the latest version?
Thanks in advance.
