Memory Card Readers and Memory Sticks
Discussion in 'Photography Forums' started by Chris Frost, Nov 2, 2003.
  1. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,757
    Cheshire
    +108
    Has anyone got a Multimedia Card Reader? What are your thoughts?
    Q1 - faster than download from camera / about the same/ slower?
    Q2 - is there a big difference in real time between USB 1 and USB 2 transfer speeds.
    Q3 - is Memory Stick Pro important or will the standard Memory Sticks from Sony work just as well.
    Q4 - what about third party memory sticks? Are Lexar and MSA any good?
    Your help appreciated.
    Regards
  2. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    I use a reader fitted into a 3.5" drive bay and connected to an internal usb 2 connector.
    It shows as a number of removalable drives and is faster than connecting my camera via usb.
    I don't know precise speed tests, but I would describe file transfer via usb 2 and win xp as "very much faster" than usb 1 and win 2000.
    Don't know about memory sticks, but I have had no problems with any brand of other memory cards (CF, SM and SD) and they all seem the same for the general stuff I do.
  3. shoehorn
    shoehorn
    Jul 2, 2003
    1,602
    The Garden of England
    +32
    I also have one in a 3.5" bay, connected via usb2 (internal).
    Basically the same details as woody67.
    It's ease of use is what appeals to me...
    I've used all types of memory card without problems - inc. memory stick - haven't used memory stick pro though.
    I'm not sure about other card-readers, but I have copied from one type directly to the other - as each 'slot' is shown as a separate drive.
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,757
    Cheshire
    +108
    Thanks for your help guys. I ordered the Lexar 8 in 1 memory card reader along with a Sony DSC-P72 from Pixmania.
    Regards
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Lexar are pretty good
