memory card info please
Discussion in 'Nintendo Wii-U & 3DS' started by buddyspudface, Jan 1, 2007.
  1. buddyspudface
    buddyspudface
    Jan 15, 2006
    337
    +15
    i cant find the owners book for the wii and was wondering if someone could tell me why i cant save things to the official memory card? iv been to all the settings and cant make it save to anything else but internal memory:mad: .
  2. Billy Hunt
    Billy Hunt
    Jun 29, 2002
    1,185
    Worksop
    +98
    I don't think you can save straight to the memory card.
    To transfer the data to the memory card go into options > Data management > Save Data > Wii here you have the tabs for system memory and sd card and can swop them over
  3. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
    I think also that you need to have run an update over t'interweb before it will allow you to use the SD card. You've probably done this already though if you can 'see' the SD...
  4. kb33
    kb33
    Apr 9, 2003
    301
    Kamloops BC Canada
    +22
    Do you need an SD card to save games fro the Gamecube ? I tried Mario Kart and it came up with "unable to save game no memory card inserted "
  5. jammedherbs
    jammedherbs
    Jan 2, 2006
    125
    Knebworth
    +9
    You need a Gamecube memory card. They plug into the slots behind the Gamecube controller ports.
  6. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,333
    Essex
    +1,018
    what size sd cards does you all use ?
  7. hillster
    hillster
    Feb 11, 2004
    720
    Reading
    +29
    2GB but thinking of getting a 4GB card.
  8. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
    2Gig Viking from Ebuyer <£20. Works fine, it's actually a re badged Toshiba card.
    I think I read somewhere that 2gig was the max size... better check that.
  9. AFSTER
    AFSTER
    Sep 28, 2005
    1,527
    48
    +56
  10. kb33
    kb33
    Apr 9, 2003
    301
    Kamloops BC Canada
    +22
    OK thanks found that ..So why do you need an SD card ?
  11. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    At the moment few people need a SD card unless your using the photo viewer but eventually as you fill up the internal memory it will allow you to backup to SD card to free up space. It also allows you to backup your saves.
  12. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,333
    Essex
    +1,018
    right. im currently using a 512mb.
    i did buy to use with my sat nav lol
    (for extra maps )
    so il be best to get a 2gb one then.
    for the wii...
    thanks il have a look about. :smashin:
  13. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
  14. TheBiGW
    TheBiGW
    Nov 19, 2005
    2,484
    116
    +1,508
    I believe you can also store games downloaded for the Virtual console on there, so if you're planning on going nuts and gettings loads of those it might be worth getting a card.
    Myself, I won't bother - seems to be plenty of room for saves/channels for my purposes on the main console itself
  15. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,333
    Essex
    +1,018
    thanks but i wont touch ebuyer with a barge pole.
    after getting ripped off by them.
    il try forums first. :)
