Megaworks 550 Satellite Speakers
Discussion in 'Home Cinema Speakers' started by Thermopyl, May 18, 2005.
  1. Thermopyl
    Thermopyl
    I have hooked two of the satellite speakers for the above system to a standard HiFi Amp (Cambridge Audio). I now receive a horrible buz/drone noise...can anyone tell me why this is???
    Thankx
  2. Fotis_Greece
    Fotis_Greece
    Jan 6, 2006
    93
    +5
    Have you found any solution?
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +599
    probably because the hifi amp is a proper amp for powering full size speakers, the megaworks speakers are not proper hifi, they are usually designed to only be fed from the matching subwoofers amplifier....
    at least im assuming you are talking about Creative Labs speakers?
  4. Thermopyl
    Thermopyl
    yes..i had a ground loop problem. i bought a ground loop bypass on ebay and it worked a treat!
  5. Fotis_Greece
    Fotis_Greece
    Jan 6, 2006
    93
    +5
    ground loop bypass? Where do you connect this? Between the amlifier and each speaker?
  6. Thermopyl
    Thermopyl
  7. Fotis_Greece
    Fotis_Greece
    Jan 6, 2006
    93
    +5
    I am thinking of connecting the Megaworks sattelite speakers toa Denon 2106 amp. The Denon is 7x90W.
    How many W is your Cambridge audio amp? Is the sound better when using this amp than using the Megaworks amp in the subwoofer?
