Megane head unit question
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Tall Bloke, Dec 5, 2004.
  1. Tall Bloke
    Tall Bloke
    My gf has a 99 T Megane with a Phillips radio cassette head unit. I bought a VDO Dayton CD changer off eBay only to find it won't work with the Phillips head unit. The later Meganes used a Tuner List head unit. Will this head unit fit into the pre 2000 Meganes and will the display and column controls work?
    Thanks for your interest,
    Paul.
  2. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    try www.coupe-club.co.uk for help with ya megane needs tell them G1OSE sent ya they will help you out
  3. Tall Bloke
    Tall Bloke
    Cheers, mate. I'll let you know how it goes.
    P.
