MedUSA 5.1 headphones help.
Discussion in 'Headphones, Earphones & Portable Music' started by DaddyDee, Jun 22, 2004.
  1. DaddyDee
    DaddyDee
    Feb 10, 2003
    1,425
    Waddington
    +89
    I have been given a pair of MedUSA 5.1 headphones but there are no instuctions with them (dad gave them me, he never used them). I have connected them up to my pc as I think they should be and I get great sound from them. There is swith on the volume control for cd or dvd. Does anyone know what it should be set to for playing games on the pc to get 5.1 surround ?
    Cheers :lease:
  2. <<ERROR>>
    <<ERROR>>
    Apr 18, 2004
    56
    9
    Cambridge
    You want the DVD setting for 5.1 games. Be sure to set your computer up to output 5.1 sound - though it will work with 4.1 output, the resulting sound quality has nothing on them being fed 5.1.
    The CD setting is for when you have plugged a (supplied) weird adaptor-thingy into the headphones lead that gives you a single 3.5mm headphone socket. It is not for the full connection to your PC.
