Medium wave quality poor in VW
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by jfk1, Dec 24, 2004.
  1. jfk1
    jfk1
    Reception of meduim wave in my 'Y' reg VW Polo is very poor. Sony unit. FM received but no in stereo - tapes ok. "Whip" aerial ok and booster makes no difference.
    Any ideas on how to remedy this?
  2. Highgord
    Highgord
    Dec 3, 2004
    169
    +9
    I would suggest making sure that the head unit is grounded correctly. If you have fitted the unit yourself, clean the earth connection and on the back of many head units you will find a terminal you can bolt a wire on to, try and connect this to a separate earth. If you still have a problem then it could be one of two things. The aerial is no good (or the cable is damaged) or the system is picking up electrical interferrence which is reducing the signal quality.
  3. diesel_uk
    diesel_uk
    pc5-91
    pc5-50
    pc5- 51 ? euro
    one of these above will make your stereo MW work better
    The + feed has to be seperated. The above are part numbers availible from Auto leads. No more than £15 for any one of them and they will work.
    The pc5-51 worked in my passat.
  4. jfk1
    jfk1
    Diesel_UK
    Thanks for that. You say the parts are avaialble from Auto leads. Is that a shop/chain or do you mean any good ICE retailer?
  5. JiMbOb_74
    JiMbOb_74
    Hi, I work for HYde park corner and fit these all the time..
    Firstly need to know what VW and how old... If its pre 2000ish it will need an autoleads 'amplifier' (its just a large diode) to suply the power to the roof mounted aerial and stop it coming back down the same cable to blow your radio up..
    Let me know and I will give you the exact part number for what you need and how to fit it..PM me if you like
  6. diesel_uk
    diesel_uk
    Halfords, any car audio shops
  7. jfk1
    jfk1
    JiMbOb, Hi.
    It's VW Polo 1.4CL, first regd Nov 1999.
  8. JiMbOb_74
    JiMbOb_74
    You will need an autoleads amplifier part number:
    PC5-91
    as someone has already mentioned!
    Hope this helps... you will have a fly lead on this to wire into the iso plug but the part has insrtuctions. need anymore help let me know
  9. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,859
    My mate has bought a last generation Pioneer CD/Tuner (1530?) for his 2000 3 Series (E46) saloon. He reckons AM reception is attrocious compared with another Pioneer head unit from circa 1994. The odd thing is that I tried his head unit in my 3 Series Touring (also 2000 E46) & found no problem with AM. :confused:
    Any suggestions gratefully received.
  10. jfk1
    jfk1
    JiMbOb and all,
    Thanks for your help. I have tried all the solutions but MW still poor. The autolead actually made reception worse. In the end I tried a 3ft length of copper wire into the back of the unit and out the sunroof. Result, near perfect reception, however, a little impractical for day to day use!
    It seems obvious that the problem lies between the whip aerial and the plug, and that probably means having it replaced by an expert as I have no idea how to get at roof mounted aerials without destroying the interior roof trim.
    Thanks once again for all your help. :thumbsup:
  11. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,386
    41
    South Yorkshire
    +13
    Some Polos have a joint in the aerial lead in the area above the driver kick panel sheck that.
    Also check the ISO aerial conection at the back of the radio as the coax centre is known to break away from the pin in the plug.
    Is the radio is the VAG Sony? if so you do not need the modulator for the turning the electronics on in the aerial base as the radio is built with the modification done internaly.
    TMH
  12. SimonG156
    SimonG156
    May 18, 2004
    121
    +3
    On a similar note, my Pioneer DEH P77MP has zero reception on MW. The alpine OEM it replaced was good. I have just done a straight swap. Any advice to get decent reception? I'd hate to add an external aerial as it would spoil the aesthetics of the car.
  13. diesel_uk
    diesel_uk
    Simon what car are we talking about
  14. SimonG156
    SimonG156
    May 18, 2004
    121
    +3
    Alfa Romeo 156 MY2000 (saloon)
  15. diesel_uk
    diesel_uk
    I will try to answer that tomorrow, I will ask my brother . I dont have much to do with Alfa's.
  16. mdenjean
    mdenjean
    Hi there, thanks for all the tips.
    I have a very similar problem as JFK1 above as I get parasites from the engine / fan when I listen to LW on my radio.
    I have benn thinking about grounding my aerial or simply checking my grounding but I simply can't find the place where the main grounding is!
    I have a W reg 1.0 polo (i.e. not current but previous generation, the simplest model).
    many thanks
    Marc
  17. gra135
    gra135
    Hi all, I`ve got similar problems with my JVC CD/Radio player in my 2002 golf, anybody got any ideas
