Medium size LCD TV - opinions?
Discussion in 'LCD & LED LCD TVs' started by TheWeevil, Nov 17, 2003.
  1. TheWeevil
    TheWeevil
    Hi, I'm new to this board.
    I've been looking for some time now at getting a flat screen to save space in my small Victorian terrace living room. The space I want to put the screen in (between chimney and wall - you know the bit) is just over 90cm wide so the screen would need to fit that. When I started looking it was for 30" plasmas with no side speakers but more recently as the new ranges of LCD's came out I was tempted more towards them.
    The screen will be viewed across the room at a distance of 1.8-2.0meters so even 30" is a bit big. I want to use it mostly for TV (via NTL cable) but also for DVD's and PC.
    So, I'm looking for a medium size, widescreen LCD display - I'm guessing 26-28" would be about right with as high a pixel density as possible.
    Had a hot tip that Toshiba had a new range that was pretty good. Net searching has revealed that Toshiba do a 26" display (W26L36) with 1280x768 res and prog scanning, but on the whole I'm finding the whole business a bit confusing in terms of LCD/plasma/price/peformance/etc
    Anyone heard about these or have opinions on other displays I should keep and eye out for? Please let me have any personal opinion and anecdotes you have - that's what these boards are good for!
    Cheers in advance,
    Weevil
  2. cjc1
    cjc1
    Oct 6, 2003
    22
    I have had a Sony KLV23HR2 now for about 2 months. At the time I looked at alot of LCD and this is the only one I did'nt leave the store thinking "is that as good as it gets" no doubt it was mostly due to the dealers setup. But if you are paying a premium price you expect a premium product.
    I also looked at 32" plasma but at the end of the day it was just too big. Having said that a 32" plasma at the time was alot better than a 30" LCD.
    Performance is excellent on Sky and DVD's. Not used the PC on it. Havent see the new Toshiba units. Were just announced when I bought. Could wait any longer.
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,914
    38
    UK
    +7
    Look at the LG 30" LCD. It has a great picture and has the speakers on the bottom so it's quite narrow and descreet. I'm in the same boat as you really, don't want a TV with huge speakers out the sides and would like something around 26". Another option is the Sony 23" but it may be a bit small.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    JVC have a new very nice 26" LCD set out, speakers under neath and a very good finish, not tacky silver!!!! this would be ideal for you mate.
  5. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,914
    38
    UK
    +7
    You have any links with pictures? I can't find a shot of it anywhere.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
