Medion MP3 problems
Discussion in 'Headphones, Earphones & Portable Music' started by Frankie Angels, Aug 21, 2004.
  1. Frankie Angels
    Frankie Angels
    I bought one of the Medion MP3 players from Aldi (July). This was a great buy for £49.99 and I've had no problems at all...until now that is!
    For the last few days, everytime I download MP3's it automatically arranges them in alphabetical order by track listing. I have followed the instructions in the booklet and taken the batteries out to "reset" the player, but still no luck.
    Model no: MD41512
    Using Musicmatch Jukebox v. 8.02
    Windows XP
    Help this is cheesing me off! :mad: :(
  2. Fatz955
    Fatz955
    Frankie
    I bought a medion MD41512 on saturday and realised i had the same problem that you described.I have e-mailed Medion Tech Support,but they haven't replied yet.In the mean time I discovered that if you rip the songs using number-title-artist (Jet Audio @ 80kbps/ 4 albums per 128M) and keep them in a directory that they stay in order. It will also arrange the directorys in alphabetical order.
    Using this way means it doe not matter which way you download them, as i just drag-n-drop now.
    Hope this helps
    Fatz955:devil:
  3. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    I have this player too. Have you guys used a larger SD / MMC card to expand the memory?
    I have played with a 64mb card I had in my camera, but my birthday is coming and I wanted to treat myself to a 1 gb card but not sure if the player would accept it?
  4. Fatz955
    Fatz955
    Just bought a 256Mb Kingston SD card.
    Seems fine but I'm still playing
    Will let you know in a couple of days what it's like
  5. pepe_peters
    pepe_peters
    Don't get the 1 Gig card. It can only read up to 512 MB without trouble.
    If you use 1 Gig it will play the songs but on startup requests to reformat the card. This can be overcome by inserting the card once the play has started.
  6. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    Thanks for your reply! I also found this out as I had bought a 1 gig card. On the first try it registered that it could only see 512Mb but played all the tracks. The card then went berserk and I have since sent it back and in my impatience bought a 20gb Ipod instead...in for a penny etc!
    I actually thought the problem was the formatting of the card which is where mine started to ave problems. If the card is formated to FAT16 it would work for a while then throw up the error message you describe.
    Oh well still kept mine anyway, still think it is a great little player!
  7. gilera
    gilera
    Nov 24, 2004
    33
    Can anyone please help me. I live in Spain and have purchased a Medion MD 6242 from ALDI. I would like to obtain a copy of the instruction manual in English if possible.
    Perhaps even a similar model would help.
  8. kwizzle
    kwizzle
    i have a medion mp3 player (md51412) and i formatted it by mistake .......please i do not have money to buy a new one ....please is there anyway of fixing it because it does not power beyond the hello screen...it shows hello then goes off.....i need help soonest please!!!
  9. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    If you have formatted the internal drive I think you will need to make sure if is formatted again to FAT16. External cards have to be done this way for the player to register them.
  10. todd
    todd
    What a great bit of kit ...39.99 at Aldi , just bought TWO for my daughters for Xmas.
    Best place for SD/MMC cards is 7Dayshop ....256M is currently 15.99GBP
  11. papegaai
    papegaai
    :confused:
    I also got the Medion MP3. In the software help file they are talking about adding playlists to the device.
    I tried to do add different playlists, like 70's, 80's, but on the MP3 player everything is mixed together and I cannot figure out how to play the songs from one particular playlist.
    On the device, you can find a playlist menu, but the playlist never appears here.
    Does anyone knows how it works?
    Regards,
    Papegaai
  12. john.hem
    john.hem
    Jul 1, 2004
    547
    46
    +249
    Kwizzle, did you format it with windows or the utility software on the CD which came with the MP3 player. What you need to do is open the Digital Firmware download (its on the CD). Don’t tick format Data Area. Click ‘Start’ and the firmware will be downloaded to your player. It will then be back to as when you bought it. When you format it, it also gets rid of the firmware. Don’t use windows to format it, use the utility software and then update the firmware.
    John :thumbsup:
  13. iderzh
    iderzh
    Mar 9, 2005
    I have bought MD41512 and encountered next problems:
    1. Kingston 256 MB SD card, when I formatted it windows xp finished to format it with message "Cannot complete format", but card was recognized by player.
    2. When I copy to SD card files it takes too much time and I don't see progress of copy.
    3. When I listen to audio book by earphone I cannot listen the voice, only music, if I listen same file by build-in speaker I hear voice clear.
    Please help me.
    Regards, Igor.
  14. djspazz
    djspazz
    hello my friends, i have a medion md80220 mp3 player, i format it by mistake and i have erase the files :s, i try toi install the driver of the cd but nothing happened, please help me, what can i do? tks
  15. phatmattuk
    phatmattuk
    i bought medion 2.5gb jukebox and software would not load and tech support was terrible so i took it back to aldi waste of time. took medion up to 10 days to reply to email and put me on hold for 37 mins until i hung up.
    now got ipod mini £125 from jon lewis.
  16. LisaMp3
    LisaMp3
    I brought a medion 256 Mb mp3 player from toy's r us i have had no problems to its starts to turn off when i press the button to turn it down and when it gets taped it turns off its driving me mad and toy's r us wont take it back. :rolleyes:
  17. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    Is it still under guarantee and do you still have the receipt? If so Toy's R Us are going against your statutory rights....
  18. trendy_geeza
    trendy_geeza
    Hiya,
    I'm kinda new to this AV forums so I hope I'm doin this right! Lol, I've got the Medion MD41512. I also got it from Aldi for £49.99. Kinda stupid but I just realised I could do firmware updates on this thing..I've tried the medion site but theres noting there...Ive even tried the CD program but no luck..Has anyone ever upgraded their player successfully? Are the upgrades even any good?
  19. LisaMp3
    LisaMp3
    WEll i have had to mp3 players one broke replaced it for this medion one now this one has broke thats why i think toys r us wont take it back. :(
  20. pspeech
    pspeech
    Help :lease:
    I have bought a medion mp3 player from Kwik Save.
    A problem with my PC has meant I have had to erase the software which came supplied with it. I've lost the CD too.
    The heldesk are dreadful and i cannot obtain another copy, rendering my jukebox no good. I can copy tracks on to it but cannot then seperate them into albums/artists etc..
    Can anybody email me a copy of the software that came with theirs? i'd be so grateful. The address is pspeechley@btinternet.com.
    Thanks all
  21. ratdog100
    ratdog100
    i formatted my medion 20gig mp3 player to fat32 with out meaning to i get a message saying check hdd ? how do i make it the right format and what is it?
  22. sanantha
    sanantha
    I have done the same mistake of formatting the jukebox and now it does not boot to display the menu options.
    After recovery through the CD utility, I can download mp3 files to it from Musicmatch. These are stored in DRM folder. but the player displays "Please check HDD" and "Wait Menu Key" and hangs until battery runs out.
    Please help.
  23. parth_kalra2000
    parth_kalra2000
    yes you can have the english manual from the web site www.medionusa.com or from www.medion.com then convert it to english a option given at top and the from cust care option in manual you may write you model number and the manual.
    please try to help me for my problem i have posted in mp3 and i-pod option
    my name in parth i have a medion jukebox md-81034.
  24. parth_kalra2000
    parth_kalra2000
    dont try the firmware updates its just a dam thing i by mistake did it and now suffering my mp3 md-81034 now just do not shows the menu option and even not able to copy music to the drive not even able to create folder in the hdd of player. please help
  25. parth_kalra2000
    parth_kalra2000
    hi,
    even
    i had the same problem of hdd hang out but ,
    i kept in my cupboard for a month and when i took it out i found it working
    i think you should try that keep it aside for a long time without using then it will start working with little problems , to hang out but after a use of a week it will work perfectly, if it shows the hdd symbol again then keep it off for some time a hour or half then it will again work
  26. mido1000
    mido1000
    :lease:
