Medion MD41530
Discussion in 'LCD & LED LCD TVs Forum' started by Pjero, Nov 28, 2004.
Tags:
  1. Pjero
    Pjero
    http://www.tietoappa.com/PDF/Medion_30_MD 41530 LCD-TV.pdf
    16:9 Flatscreen LCD-TV
    Physical resolution 1280 x 768
    Screen diagonal 76cm (30'')
    Angle of vision:- Horizontal 170º (typ)- Vertical 170° (typ)
    Contrast ratio: 500:1 (typ)
    Brightness: 500cd/m
    Response time: 16ms (typ)
    Price: 1500€ (I don't have much money :( )
    What do you think? Is it a good choice?
    Thanks for your comments, in advance,
    Pjero
  2. gusf1
    gusf1
    Sep 25, 2003
    114
    Edinburgh
    +6
    This looks like an updated version of the Medion 30" LCD I have, can't comment on that specific model but what I have found for the one I own is
    Pros:
    Looks decent
    Fine for football, fast moving pics no problem
    Cheap
    Lots of input choice
    Picture in Picture
    Cons:
    Black levels not quite black, dark grey, but acceptable in my opinion
    contrast in dark scenes not the best, but again you do get used to this to some extent
    Hope that helps!!!
    There is a long thread somewhere on here about a Medion 30" LCD with much more info than this
    cheers
    gus
