MEDION 2.0GHz LAPTOP for £899
Discussion in 'Desktop & Laptop Computers Forum' started by Mr Pink, Jan 16, 2003.
  1. Mr Pink
    Mr Pink
    I would like to get a PC to act as the DVD player, scaler, de-interlacer, but me wife really needs a laptop. As I have just spent a large wad of our well earned cash on my Home Cinema Room, and we can’t really afford to by two new PC’s, then it looks like I’ll have to get a Laptop that can perform both functions.
    I am pretty clued up on PC’s and would have no trouble piecing one together, but I know nothing about laptops. I have been looking at this on in PC-World…
    http://www.pcworld.co.uk/store/mart...ijmcefecfgmdffgdfgj.0&page=Product&sku=805024
    Yes I know, I don’t really want to get one from PC-World, but if the thing will perform well within my HC setup then maybe I should.
    Can anyone comment on this Laptop or maybe recommend an alternative. I would prefer dedicated video RAM and the ability to output DD & DTS straight to my amp so I don’t have to buy external sound card.
    Any words would be appreciated.
  2. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    the link didn't work for me...
    if you do a search, I went for a laptop for the same reasons and bought similar about 6-9 months ago... not using it for full HTPC duties now, just occasionally.
    you definitely need a decent gfx card, pref nvidia or ati... none of the shared memory ones will be guaranteed to do a custom resolution with powerstrip and a projector for starters.
    as long as the laptop has a soundcard with spdif out then it will do dd/dts duties... look for it in the spec.
    so a laptop of decent spec would be fine for DVD duties.
    the scaler/ deinterlacer bit may not be possible though - how were you going to try and do this? dscaler only works with pci cards afaik.
  3. lynx
    lynx
    Jan 20, 2002
    4,636
    It always rains.
    +302
    The session id has timed out. Go to any page and change the id to ...805024 and it will work.
  4. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    thanks lynx - got it now... (geek!;))
    I'd avoid the shared memory or duff make chipset..
    the toshiba one at £999 is a better gfx card, model no TOSHIBA 2410-504, P4 1.7ghz, with an nvidia gfx card..
    http://www.pcworld.co.uk/store/mart...0&page=Product&sku=777133&category_oid=-15257
    some of the more standard oem cases have the spdif though,
    the current "the computer world" store (old time/tiny) has one for about £899 with a decent gfx and definitely has an spdif out..
    also buy now, pay 2004.
  5. lynx
    lynx
    Jan 20, 2002
    4,636
    It always rains.
    +302
    One little fly in the ointment though
    :D
