Media Streaming Problem
Discussion in 'Playstation Forums' started by Andy3105, Jun 8, 2009.
  1. Andy3105
    Andy3105
    Nov 18, 2005
    1,669
    2
    Skelmersdale
    +263
    :hiya:
    I don't know if this has been convered elsewhere and I have looked in every place I can think of without success, anyway I set up WMP11 to share media and my PS3 was discovered and accepted, when I went to the PS3 I could see my laptop on the screen and I was happily streaming stuff in seconds.
    The following day I switched the laptop on then the PS3 and ever since the PS3 cannot find the laptop at all, it finds a different on upstairs but not my one.
    Any ideas? :confused:
    I am really frustrated by this and I can't solve it at all, I am running VISTA Home Premium 32bit and I have checked that all the files necessary are running etc...............
  2. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Try temporarily disabling all Software firewalls on your laptop. Including the Windows built in one.
    Also make sure the PS3 is set as an "allowed device" in win media player on the laptop.
    Failing those two install this and wonder why you ever used WMP to stream ;)
  3. Andy3105
    Andy3105
    Nov 18, 2005
    1,669
    2
    Skelmersdale
    +263
    :smashin:
    Cheers Mate
    I reckon I'll have a go at it later on today, I know I can copy video etc to a memory stick and then either playback or copy to the PS3 but it's such a pain, hopefully this will solve it all.
    Now, if i could just find out why my 360 shows my PC as "PC Not Listed" :confused:
  4. Digital Tench
    Digital Tench
    Dec 16, 2004
    4,315
    South London
    +906
    Are you using DHCP to assign addresses, that would explain it.
    Also, enable uPnP.
  5. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    why would using DHCP affect it. Your PC wil usually lease the same IP address.
  6. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    Antrim, Northern Ireland
    +388
    I've just stumbled ascroos this topic and I'm interested in sharing the media on my pc with the PS3. On my pc I've set it to share media. What do I need to do on the PS3 to complete setting it up?
    Baz
  7. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    What are you using, Windows Media Player ?
    You've enabled sharing via that app ? If so, and you have some media in your "shared folders/library", and have a wired/wireless connection to your PS3, you should be able to switch your PS3 on, and you should be able to search for Media Servers and it will pick it up.
    You can then navigate through the (rather crappy) folder structure to find your files and play...
  8. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
  9. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    I'm using WMP 11 on Windows Vista.
    Baz
  10. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    Follow instructions above then....
  11. Andy3105
    Andy3105
    Nov 18, 2005
    1,669
    2
    Skelmersdale
    +263
    :hiya:
    Okay so I downloaded and setup PS3 Media Server, the result.............:smashin::smashin:
    Fantastic mate, all sorted and happy as larry!!!
    Now like I said, I just need to find out why my 360 keeps coming up with "PC Not Listed" :confused::confused:
  12. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    I got WMP setup with my pc lastnite, I just had time to have a quick play around with it. It seems I can only play one track at a time inteads of a whole album. Is this the norm or am I missing something?
    Baz
