Media recommendation for LG4040B
Discussion in 'Blu-ray & DVD Players & Recorders' started by allen6000, Nov 22, 2003.
  1. allen6000
    allen6000
    Can anyone recommend which dvd-r media to use on the LG4040B.
    I'm about to order it and not too sure which brand to go for.
    Cheers.
  2. dazzer123
    dazzer123
    Sep 30, 2002
    402
    Stoke-On-Trent
    +3
    Hi I use ritek -r discs and have also used arita +r discs which apparently is a name ritek use in the states both worked very well
    It will burn to cheaper princo discs but these are generally a very poor quality disc it is a good drive though chuffed with mine.
  3. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    I use TDK -R, -RW & +RW and have had no problems or coasters. The -R & -RW work fine in my Pioneer 656 & Panasonic E60.
    * The TDK -R really do write at 4x in the LG4040 ! (firmware rev. 301)
