Media Portal/TheaterTek woes
Discussion in 'Desktop & Laptop Computers Forum' started by sean.pittaway, Aug 18, 2005.
  1. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    I wondered if anyone can help out, i am trying to use TheaterTek with Media Portal but ill be dammed if i can get it working.
    I set it up using the correct path and params in MP setup, start MP, goto Movies then click on a hard disk stored DVD, all well so far :)
    MP now pauses and TT starts, but the picture never changes, TT is playing and i can here the sound, but nothing happens on the video side - all i see is teh last MP frame.
    MP front end is disabled and TT shows up in the alt_tab list.
    If i tab to TT nothing happens.
    If i terminate TT it kills of MP.
    I guess this that i am doing something stupid, can anyone help?
    Cheers, Sean.
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    Any reason why you are trying to use TT with Media Portal?
  3. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    I tried missing with the built in player and it never looked as good as TT.
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    Strange as it use will use the same driver that you installed with TT - the Nvidia drivers.
  5. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    I had a chance to play arround over the weekend (and someone told me the answer on the MP forum:))
    So, In case anyone else every has the same problem...
    You are being stupid, you have ticked "always keep MP on top" :)
    drummerjohn, no idea why it looks better, like you said both are using the same codec / ffdshow settings...
    Maybe TT's settings are better "out of the box"?
    BTW, I am really impressed with Media Portal, i tried it a while ago and it was a bit flakey, now i perfer it to meedio (tried the trial)...
    Very impresive for non-comercial software!
  6. DanH
    DanH
    Feb 16, 2005
    604
    +56
    Agreed.
    Once its set up properly, which can be a little quirky, i thinks it much better than MCE. I also used to use TT with it, but now use the nvidia drivers that came with TT in Mediaportals player. On renderless vmr9 and resizing etc in ffdshow, i cant see a difference in PQ using TT, so for simplicity sake i use the MP player. It resumes playback properly for one...
