media portal help
Discussion in 'Home Entertainment Computers' started by mr ooops, Jan 30, 2009.
  1. mr ooops
    mr ooops
    Mar 4, 2003
    3,659
    103
    Hardwicke and Wotton
    +349
    hi all, getting to grips with media portal now, and have it set up just about right, with 1 exception, for the life of me i cant add album covers to the main menu, ive added the album cover and its viewable once you select the album from the main menu (ie when you see the individual track lists) but when you have the list of the albums youve got on the hdd all i can see is tramsparent folders? anybody know what im doing wrong?
    thanx for any suggestions
    jason
  2. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    Is your music tagged? If so have you imported it into the database??
    The default shares view is not great and the library views are much much better
  3. mr ooops
    mr ooops
    Mar 4, 2003
    3,659
    103
    +349
    not sure to be honest, ive added to the database (its all music downloaded from amazon.co.uk) of thats any help
    thanx
  4. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    Check the options in the config app. There are lots of options to do with jpg creation there.
    You can then change the view from shares to say genre and all the album art should be ok
  5. mr ooops
    mr ooops
    Mar 4, 2003
    3,659
    103
    +349
    finally worked it out, mediaportal didnt like my file structure, looking through my mp3 folder i noticed the ones that had cover art on the main screen were saved c:/mp3/artist/songs.mp3 the ones that didnt work were saved like c:/mps/artist/albumname/songs.mp3 so getting rid of the albumname folder they now all work :)
    such a simple answer took me best part of 5 hours!!
    thnks for the suggestions jameson_uk, looked into the tag bit and now have a tag editor so any that miss this info i can now edit etc :)
    thanx
