Media Portal and Nebula - does it work?
Discussion in 'Desktop & Laptop Computers Forum' started by DaveP, Mar 3, 2005.
  1. DaveP
    DaveP
    I've built a test PC to test out some things. One of which was using Mediaportal with the Nebula card.
    I've downloaded the latest MP and I have the latest Nebula drivers but when I try to configure MP it gives me a list of TV cards but the Nebula doesn';t appear to be there.
    Has anyome got this combo working and if so, how?
    Dave
    EDIT: I can't get the Black Gold to work either!
  2. groovyclam
    groovyclam
    Mar 28, 2004
    202
    It won't work until Nebula release BDA drivers for the card.
    The best you could do at the moment is to launch the DigiTV exe as a program launch from a MedioPortal menu option.
  3. DaveP
    DaveP
    Thanks, does the Black Gold card work them? That has BDA drivers.
    But again, it does not appear in the list
    Dave
  4. northernmunki
    northernmunki
    Does this work OK as it might be this weekends project.....?
    http://www.nebula-electronics.com/Downloads/BDA_Drivers.asp
  5. WBC
    WBC
    The Nebula has BDA drivers.
  6. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    Only the PCI variant at the moment and it means you can't use DigiTV at the same time which is the only problem.
