Media Player
Discussion in 'Video Streaming Boxes & Services' started by meikle, Feb 1, 2009.
  1. meikle
    meikle
    Sep 18, 2007
    30
    9
    Motherwell
    Hi all,
    I've got one of these media players & use it to store & play Music, Movies & Pictures on my TV.
    It's got a 160 GB hdd fitted along with it's own wee software setup.
    What I want to know is can I instal a newer better software to run the media, if so can anyone recommend one & tell me how to instal.
    I've just put all of my CD collection on it but some folders are comming up emrty.Thanks for any help
    ca076_g.jpg :lease:
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    If it has a make and model on it that might help people to answer your question.
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    And once you've established the brand I'd say first thing is to check manafacturers website and see if they have any software updates online.
  4. lfcfan_uk
    lfcfan_uk
    Nov 6, 2008
    98
    +7
    the two chaps above dont lie :)
    make model + check the website
  5. meikle
    meikle
    Sep 18, 2007
    30
    9
    Motherwell
    Just got the box it came in, no make, model no mention of a web site for support or upgrade usual ebay rubbish.
  6. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    You are not likely to get a lot of replies then sadly :(
  7. Smurfin
    Smurfin
    Aug 13, 2002
    21,462
    +4,393
    When you install the software, does the software have a name?
  8. Whisper
    Whisper
  9. Smurfin
    Smurfin
    Aug 13, 2002
    21,462
    +4,393
    Sorry, I don't think you'll find many people on here who have come across this :(
  10. John7
    John7
    Aug 6, 2004
    2,802
    +968
    If the folders are showing up empty, the files are probably of a type unsupported by the media player?
    The "software" is ususally bespoke to the media player and will not be compatible with any other type, so you won't be able to change it. A browse through the manual or the manufacturers website may be useful to you.
  11. meikle
    meikle
    Sep 18, 2007
    30
    9
    Motherwell
    Hi all,
    Whisper, that's the beast (LOL).
    When bought there was no software to load, I just stuck in a HDD, Formatted it then started to load it with MP3s etc.
    It all worked fine until I started to paut a lot of music on it then when I opened a folder it says it's empty but when connected to PC it's all there.
    The manual shows how to update firmware but instructions are [email protected]
