Media PC Build
jsheldon
Seriously thinking of building a Media PC to act as a server in the house for cds, dvd recording, etc etc. Been thinking of this for a while, and now Sony have brought out a media receiver which will decode mp3's etc which will plug into the TV and Amp setup I have and have the same remote as my other Sony stuff, this has spurred me onto looking into this seriously.
I'm after a small PC that will fit in a cupbaord, along with a large HDD (200 gb) and a high quality DVD recorder/rewriter. I'm not sure if I would need a top end video and sound card for this type of application. I would also fit a digital TV card , network card etc .I've already got a spare TFT screen and wireless keyboard/mouse. The machine would not be used
for anything else so I dont't think I would need a high end processor??
I would also have the server connected to broadband permanently, although would use a laptop to surf connected through the wireless network I already have.
Any ideas where I can find such a PC or what components would be best for this type of application, ie good processor/ motherboard/ dvd recorder/ hdd/ small case etc.
The Sony stuff says it intergrates with the Vaio PCs but I would have thought the Network Media Receiver comes with software to intergrate with other PCs so that the remote will operate the PVR etc functions on the PC.
I will probably use a wired link to my router rather than wireless for the time being, but can always add a bridge/acces point (never sure which you use) to the Media Receiver at a later stage. (Im 54 mbps so should be up to the job)
URL
Hi - what i sthe sony device, and what does it offer?
Did you look at a Kiss?
I use a couple of Kiss's right now for the same thing...
I stream most of my DVD's and all mu MP3 plus digi photos....
As for server... not really an issue... anything will do - even an olf PII.
Just make sure your LAN is up to it if you have more than one node streaming. Most HUBS are just that - HUBS not real switches.
I upgraded to proper 3com switches and it made a huge difference when using 3 streams concurrently.
I also find teh mobo ethernets are often crappy - even an old 3c905 does much better!
D
🎬 The Top 20 Most Anticipated Movies of 2024
Back
