Media Centrte PC - Location?
Discussion in 'Microsoft Windows' started by glasgow boy, Sep 16, 2005.
  1. glasgow boy
    glasgow boy
    I was originally going to buy an under TV type Media Centre such as the Evesham or Hi-grade. In the interests of reducing noise and minimalism, I'm now considering going for a more traditional stype PC and "hiding" it away in a cupboard.
    The question is - What is the maximum "ideal" length of cable run between the PC and my AMP / LCD screen without loosing too much quality?
    Any suggestion of the type of interconnects to use?
  2. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    I am quite sure its don't exceed 5 meters or you will have quality loss on DVI/VGA and possibly the same on audio.
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,268
    103
    +490
    Site the PC wherever you like then access over the network it using a modded Xbox running the Media Center Extender software.
  4. JonMace
    JonMace
    Nov 20, 2002
    2,539
    83
    Kent
    +207
    My Xbox is louder than my DMSII
  5. lisag
    lisag
    Jul 14, 2004
    5,864
    Essex
    +367
    Or the xbox 360, but no support for divx/xvid/vobs.... yet!
  6. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    Well the 360 will come with a BIG external PSU, and it will prolly be just as loud as the old xbox..., but i'd get it anyway, and I don't think it would be ideal to store a 360 under the tv, need to put it on a desk or well ventilated place.....
  7. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    Not so sure on that.
    The loudest part of an xbox is its disk. This is being replaced in favour of the 2.5" type which by design are a lot quieter.
    I don't ever recall my xbox's power supplies making a noise .... not sure if thats what you were suggesting but, if yours is I would recommend you get it checked out! :D (Maybe I haven't heard it over the HD's though!)
    If the PSU is external then this means you can drag it away from the box and put it somewhere where its ventilated, out of sight and quiet - if it makes any noise. This design would of reduced any internal fan requirements inside the box itself and also helped reduce noise again.
    Ive heard through Chinese whispers that the x360 is in fact very quiet. But, we know about Chinese whispers don't we! Not long to wait to find out for sure though :thumbsup:
  8. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    buy a Liteon 2010 netplayer (£85 from SVP) and a wireless router
    then you can play media from any PC in the house on your TV
  9. Tezdread
    Tezdread
    I'd advise you swap any fans if you go for a PC version (PSU included)
    I have a Shuttle XPC, slightly modded coz it was getting hot this summer when continuous playing music/movies so had to cut a couple of blow holes (but long live case modding!!)
    anyho... I'd recommend these
    http://www.casetech.co.uk/Coolermaster-ULTRA-SILENT-80mm-Case-Fan-SAF-S84-E1-p-16318.html
    I just bought three and they are 'very' quiet certainly can't hear them when movies/music is playing, even in the quiet parts and the box is right next to the TV and I'm yet to change the 40mm PSU fan from the standard so I'm guessng that will reduce noise even more
