media center remote questions
jaymar13
I have a media pc and use the windows media center. i need a remote and IR sensor to go with it that is well reviewed but within my budget, £20/£30 max. im not too worried about the remote style because i will be using my all in one media remote (philips sru 9600) so it just needs to be reliable really.
my main concern is what type of signal media center usb sensors use i.e if they are all likely to be the same for windows or different to each IR sensor? if they are all usually the same, then i shouldn't need to buy a remote, just an IR sensor and i can borrow a media remote from a friend to teach the signals to my philips sru 9600.
any advice appreciated folks and any links to cheap + reasonable quality will be very helpful :) thanks
