Media Center Receiver Service
Discussion in 'Microsoft Windows' started by bewilder, Dec 29, 2006.
  1. bewilder
    bewilder
    Dec 29, 2006
    2
    I have started to receive the following error reporting box every 30 secs or so. It is really annoying!
    Media Center Receiver Service has encountered a problem and needs to close. We are sorry for the inconvience.
    Can anyone help me to stop this message coming up?
    Thanks>
  2. peskywinnets
    peskywinnets
    May 8, 2005
    1,157
    48
    +59
    funny you should mention this....I read online where some MS bod said that it's likely to be a bad tuner card driver - indeed my terratec cinergy T USB XS driver was causing said problem. I narrowed it down to the actual problematic file (it's shown within the error window you're seein)...replaced with stable file - sorted.
    You can prove the point by disabling your tuner card under device manager....error should stop.
  3. peskywinnets
    peskywinnets
    May 8, 2005
    1,157
    48
    +59
    Just an update here....apparently it's a buggy PsisRndr.ax and PsisDec.dll (which are in your system32 directory)
    The solution is to install MCE rollup 2, or alternatively, download the two files here & slap 'em in your system32 directory.
    http://www.terratec.it/supporto/psisdecd.zip
    Job done.
