Media Center 2005 error
S
smalljb
I get error message "Your video card or drivers are not compatable with media center". Was working when turned off at night bad when turned on in morning. Had been working since August, but went down another time along with McAfee security system. Computer manufacturer worked on it for 8 hours, then suggested I back up every thing and reload Media Center XP 2005 operating system. Got to be a better way.
Mac Sami
What graphics card do you have in the system?
mugsy
Go to start...run type dxdiag and press OK. Click the 'Display' tab and are DirectDraw and Direct3d enabled? If not try re-installing the graphics card drivers if you have them or download the Catalyst drivers from the web.
Do you have any remote control software eg VNC installed?
jc73
I've had this message very occassionally on my MCE. I just ignore it and reboot and it works. Gotta love Windows :rolleyes:
S
smalljb
Ran test Direct Draw not available, Direct 3D enabled and past all tests, no as to remote software.
Video from TV plays in Microsofrt Movie Maker.
Can change chanels from Media Center. It changes my TV set.
John
S
smalljb
work one time long ago but not now. re-installed driver still no good.
John
mugsy
DirectDraw needs to be enabled for MCE to run so work on that. This happened to me and it was down to some remote control software (VNC) installing a mirror display driver that somehow took over as the primary display. If you right-click 'My Computer' and choose Manage then click on Device Manager is there anything under Display other than the VGA card?
S
smalljb
Under Display Adapters within Divice Manager the following are shown
Radeon X300 SE 128 MB Hyper Memory
Video Graphics Accelerator
John
S
smalljb
Did you try the Catalyst drivers? http://ati.amd.com/support/driver.html
Other than that I'm out of ideas I'm afraid - maybe you will have to backup and rebuild it :rolleyes:
I finally solved the problem. Theinfrared remote sensor moved on the TV and was not recognizing the signal. I reposition it and the TV came back. Ther is no way to tell when you have it in the proper decision. You would think Dell techs woud have had this as one of their first things to check.
Thanks for your help.
