Media box question for 435 XDE owners
Discussion in 'Plasma TVs' started by hshortt, Apr 6, 2005.
  1. hshortt
    hshortt
    Mar 27, 2005
    27
    3
    Hi Guys,
    Please can you answer this question. The back of the Media box on the XDE should have a digital tuner connection point and a seperate Analogue tuner connection point. Can you please confirm this?
    Howard
  2. reckless
    reckless
    Dec 21, 2003
    983
    28
    +30
    If I remember correctly (I can't get digital) so never had need to set it up, there is one aerial socket for digital and another for analogue.
    If you wish to make doubly sure, if you go to pioneer's website you can download the manual in pdf to check.
    Hope this helps
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    That is correct, there are 2 rf inputs.
  4. hshortt
    hshortt
    Mar 27, 2005
    27
    3
    Thanks Lads! Made me a happy man and got tvandvideodirect.com a new customer.
  5. Drd
    Drd
    Jan 22, 2005
    1,816
    Approaching the doghouse at great speed
    +246
    The digital input also has an output alongside so you can loop through to the analogue input (or via recording device to analogue input)
    Regards
    Ian
  6. hshortt
    hshortt
    Mar 27, 2005
    27
    3
    Thanks Drd,
    Loving this screen even more now. Just can't wait to get it home and mounted!
