Medal of Honour (PS2) problem
Discussion in 'Playstation Forums' started by Bogside, Jun 4, 2003.
  1. Bogside
    Bogside
    Sep 20, 2002
    3,137
    Stockport (ex Derry)
    +417
    I haven't played this game for ages but decided to put it in last night. But after the loading screen it won't boot up and tells me to insert a controller. There are 2 controllers attached and I have no problems with any other games.
    Can anyone help me? Will the original manufacturer give me a replacement disc if I return it?
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Not sure if you'll get a replacement, but I've had this problem before on other games when using extension cable and/or a multitap, if you've got either of these then just plug controller 1 directly in.
  3. Bogside
    Bogside
    Sep 20, 2002
    3,137
    +417
    Thanks for replying, but I don't have either connected. Might remove controller 2 and see if that helps.
