Measuring spec of my centre speaker
Discussion in 'Home Cinema Speakers' started by gm0x45, Mar 20, 2006.
  1. gm0x45
    gm0x45
    Sep 21, 2005
    104
    My centre speaker is not working properly, the sound is dull and dialog not very clear. I would like to measure the spec of this speaker, and, having a SPL meter, I was thinking to use my PC to play some audio file of basics sinewave at different frequency (from 20Hz to 20 Khz) and record the Db level measured as a function of the frequency played. I've made a quick google search of such basic files but can't find any. I'm sure there is no problem of copyright to ask any of you if you knows a website where I can pick such trivial files. Many thanks.
