measurements of a 42" plasma
Discussion in 'Plasma TVs' started by Stampax, Aug 3, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,308
    Northampton
    +52
    I'm going to cut out a piece of carboard and see if a 42 inch plasma is too big for my lounge, but then i got the thinking- exactly how do i measure it - is a 42 inch plasma 42 inch diagnal? How large are they from one side to the other - ie justthe actual viewing screen, not the plastic?
  2. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    it's the viewing screen...you need to access the online manual for whatever screen you are thinking about to get the full dimensions
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,820
    2
    4
    137
    Garstang, Lancs
    +1,524
    42" is just the diagonal sreen measurement.
    There are measurements for the fujisu on www.plasmavision.com
    The measurements for the pannys (including bezel):
    1178 x 730 for the PV500
    1068 x 701 for the PE50
  4. Stampax
    Stampax
    May 6, 2005
    1,308
    Northampton
    +52
    Cheers mal - just what i wanted to know - now to find a carboard box the right size!!!!
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    A plasma box is ideal for this
  6. dodgyd
    dodgyd
    Jul 8, 2005
    838
    +71
    :clap:
    Dave.
