Me new TV holder
Discussion in 'Home Cinema Building DIY' started by Taz, May 19, 2003.
  1. Taz
    Taz
    going together... Holes are just for cable management.
  2. Taz
    Taz
    Sub WOOFER going in!
  3. Taz
    Taz
    LCR600 in with mm to spare! ... hole waiting for Sub (B&W ASW675) or a plant :D
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    LCR 600 mate!
    :D
    Looks damn good though.
  5. Taz
    Taz
    oops! cheers for the heads up Rick! :D
    BTW peeps this was a design inspired by ReTrO :smashin:
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Are you thinking of doing anything to the edges?
  7. Taz
    Taz
    I have a bit of work to do on it still, needs a bit of sanding and a coat of polish etc, may look at silver edges to match the rack, but got to get the RTP 15 sorted first.
  8. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    me wants your rack, please sell me your rack :) :kisses:
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Wow Taz t5hat is good stuff and alot tidier than the last time i saw a piccy of your front room!
    PS some modding needs doing in Gaming Classifieds when you've finished your DIY.
  10. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Very nice mate :D
    What material did you use ?
    Cheers, Lee
  11. Taz
    Taz
    Its 18mm MDF veneered with anegre the panels are lipped with koto.
  12. Taz
    Taz
    You couldn't afford it ;) :D
  13. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    +349
    funnily enough the girls in soho said that too, prolly right though :)
    very nice peice of kit
  14. Taz
    Taz
    Thanks mate, made by myself and ReTrO :D
  15. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Taz - May sound like a stupid question but is it not a bit flimsy?
    Only ask as I built a desk very similar in design and you could blow on it, and watch it sway from side to side.
    Although mine was a bodge it and leg it job, yours looks a lot more proffesional.
  16. Taz
    Taz
    Flimsy it aint Shoka, to test it I climbed on top of it and jumped up and down and it didnt move at all, the back panel of the sub enclosure us doweld all round to prvent any movement in the top sections we worked out that even if the back panel had been 4mm ply it still would have taken the weight of the TV!
    anyway, Mick is pictured stood on it and he weighs the same as a cadillac! :D
  17. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Taz ... your old TV rack ... is that one of them wire jobbies from Argos??
  18. vexorg
    vexorg
    Dec 11, 2002
    284
    16
    Dublin.
    Taz
    How much for the sub woofer, I like em a little bigger myself :)
    Not sure if I read the thread correctly, if you made the equipment rack as well, what is the silver edging, paint... veneer or metal?
    Thx
    Vex.
  19. Taz
    Taz
    Yes I made the rack myself, the edging is sold wood sanded untill very smooth, then I applied silver guilt cream as used on picture frames. The whole effect was to match the light wood and silver of my B&W's.
    See here for rack details... http://www.avforums.com/forums/showthread.php?s=&threadid=32192
    Yes mate it was / is :)
  20. nathan_silly
    nathan_silly
    Taz, just asking- could you build me a large cab?
    Say 1.5M high, 55cm wide, 50cm deep. How much would you charge? It'll need to be strong, hold about ~100KG.
  21. Taz
    Taz
    I could, but posting it would be a nightmare! what you wanna use it for? PM me details so as not to throw this post off topic
