Me again! more questions
Discussion in 'Plasma TVs Forum' started by BizBo, Apr 6, 2005.
  1. BizBo
    BizBo
    Mar 26, 2005
    50
    I have the PWD7 unit with scart. This is my plan..
    Order one of these units here
    this will connect to my Harmon Kardon DVD22
    The scart board will connect to my Sky+ box.
    :lesson:
    1. Now where can I get leads to connect DVD22 to the Componet board?
    2. Will PQ be ok from SKy+ to Scart on the pwd7 and if not what do I need to do (cheapest option) :lease:
    3. And I am ordering the correct component board? :smashin: :thumbsdow
    Thanks peeps!
    Darren
  2. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +476
    as per my previous reply and if its the same board yes it is the right one...that links not working just now but you can get cables form a number of places including mark Grant who you will find in the cables section here on the forums or av-sales who do the van damme rca to bnc component cables. Scart will give a fine picture, some say a bit soft, but try it first and if you don't like it you can always buy the js rgb to vga converter.
  3. BizBo
    BizBo
    Mar 26, 2005
    50
    That company I was going to use, well don't bother, hidden charges and things.
  4. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +476
    try av sales then mate.......
