MD5 Line out cable
B
Bazz
What /where is special about the lineout cable.Are they Sony Walkman specific or will they be stocked by PCWorld etc (uk)
TIA
Bazz
S
shadowritten
There are two types of line out cable that I'm aware of. One sort has a 3.5mm jack at one end, and red and white phono leads at the other. I use one of these with my Technics hifi to link my HD5 into the AUX sockets at the rear.
The other sort I know about has two 3.5mm jacks, one at either end. Some smaller Sony micro systems seem to use these.
I'm sure other types exist. I got a JVC one (for the hifi) at Curry's for £10; and the 3.5mm to 3.5mm one I got for £14 from a Sony Centre - forget which make it is.
Hope this helps a bit.
G
Gonkenobi
I am currently using the jack to two phono leads and no problem at all. I made a great investment on it : 5 €
Regards
A
Aargh
A good thing to note is that if you have bought a Sony digital camera, they probably supplied you with a cable that is 3.5mm to twin RCA. This cable is meant for showing your images / video on your TV, however the contacts on the 3.5mm jack are exactly the same as for a stereo sound source and wil work well to hook your player up to an amp / speakers.
BIGRED
Established Member
sorry to stray slightly off topic ........... you know when listening to hd5 through stereo with the audio out setting as i do of an evening then half asleep the next morning on my way to work i lose my hearing cause i forgot to switch it back to headphone output ......... well this is new to me (prob not to others ) but i started using my new mc40elk remote this morning for the first time and with it plugged in it automatically defaults to headphone audio out , no more lose of hearing for me then .......... i told you it was of topic and i've now realised probably of no intrest to anyone but seeing as how i have just typed all of this out i can't be bothered deleting it :boring:
IanPM
Established Member
It is a good point you made, and I found it interesting and worthwhile. So thank you.
B
Bazz
thanks for your replies and help.
I am , however , still not sure because the lineout socket on my Hdd NW-HD5 is rectangular and approx 8mmx2mm.
Any more info for an old fart fast becoming out of his depth?
cheers
bazz :confused:
S
shadowritten
cheers
bazz :confused:
Panic not, dear Bazz, for what you refer to has nowt to do with the line out - it's the jack for the optional remote :D The line out shares the standard 3.5mm headphone jack, so it's all good :thumbsup:
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
