MCE2k5 on a hdtv questions
Discussion in 'Microsoft Windows' started by chadwick626, Oct 18, 2005.
  1. chadwick626
    chadwick626
    Aug 19, 2005
    26
    i just had an issue with severe flickering which i havent looked into yet but if anyone has an easy solution fo r me let me know...
    im using a x800 gto2 and a dvi>hdmi cable.
    the screen doesnt look as good as i thought it would.. does anyone do any gaming on large hdtvs? hows it look?
    what adjustments do i need to make? will it automatically transmit 1080i or do i need to set it somewhere?
    any tips to make it look good for playing extremely graphically intensive games?
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    you can overclock you card to an x850xt pe...
  3. JayList
    JayList
    Will let you know when I get my dlp on fri. Otherwise Razor should know.
    Do you use PowerStrip?
  4. chadwick626
    chadwick626
    Aug 19, 2005
    26
    powerstrip? not farmiliar with it?
    and yeah i know i can.. ive got the stuff for it im just having a really bad flickering problem with the display on the tv and i dont have any monitors laying around. ive been doing everything through vnc on my laptop and once i get the monitor thing straightened out ill start to make it mine. just got it 4-5 days ago.
  5. ACMErubberDuck
    ACMErubberDuck
    May 26, 2005
    123
    Dublin
    What resolution have you got your MCE machine set to?
  6. chadwick626
    chadwick626
    Aug 19, 2005
    26
    856x480p
    its a 56" 16:9
    i got it looking pretty decent with the help of powerstrip (thanks everyone)
    but the sides are slighty arched in.. like they are with a monitor but with a monitor u have the option to adjust that.
    my biggest problem however is the screen is slightly shiftying up and down, one line up one line down one line up.... etc... anyone have any idea how i could fix this? is 480p what i should be running my tv at?
    also when i try to run aquamark3 the title screen works but when i click start the test the screen goes into active lines of horizontal "static." the program displays fine on the laptop if i go into the desktop through vnc and t displays fine on a vga monitor. the static stopps when the test is completed. any ideas about that? im hoping it wont do that any time i play a game cause i built this with the intention of doing some heavy gaming
