MCE2005 Stability on my Artisan LXH
Discussion in 'Microsoft Windows' started by james25182, Mar 26, 2006.
  1. james25182
    james25182
    Oct 20, 2004
    3
    Hi all,
    I'm hoping you'll help me out. I have an Elonex Artisan LXH which I got about 2 months ago. The problem is that I'm not finding it very stable. It needs rebooting about once every two days to resolve problems like:
    • Failing to resume from standby
    • Crashing when starting My TV or My Music etc.
    • Failing to pick up a TV signal
    • Failing to play DVDs
    I was kind of hoping the MCE would "just work" other than a few virus checks etc.
    How stable does everyone else find MCE? Better than mine or about the same?
    Cheers,
    James
  2. GingerTez
    GingerTez
    Feb 27, 2006
    144
    Altrincham
    +3
    I've had an Advent DHE2000 (which may have the same internals... certainly looks similar from the outside) for a few weeks now and the only problem I've occasionally had is that after the screensaver kicks in I sometimes don't get the picture back when I start using it again. I've disabled the screensaver and not had the problem since.
    If I were you I'd investigate getting it exchanged. Although it's a PC inside the box you bought it as a media appliance - if a DVD player or video recorder did the same you'd take it back and demand an exchange so I'd do the same for this.
    Cheers,
    Tez.
