MCE2005 & PVR150 Loss of Signal error
Discussion in 'Microsoft Windows' started by thefair1973, Apr 27, 2007.
  1. thefair1973
    thefair1973
    Jun 28, 2005
    113
    Hertford
    +3
    OK, I'm fed up now! I've spent all day building & installing my HTPC and now when I try and watch live tv in Media Centre, all I get is the loss of signal error. I'vre tried re-installing the driver, re-cabling the SVHS cable, re-running the tv setup in MCE but all end with the same result.
    I have installed all of the MCE hotfix rollups and basically nothing is working.
    Anyone else had this and if so, can you tell me how you resolved it?
  2. alfaevans
    alfaevans
    Sep 15, 2006
    121
    +5
    My issues turned out to be not having the latest drivers. Sorry that doesn't help you.
    Out of interest have you tried using composite just to see if you get the same prob (I know composite is not as good but just to see if you get the same probs) ?
  3. thefair1973
    thefair1973
    Jun 28, 2005
    113
    Hertford
    +3
    there is no composite video out on teh Sky+ box, so I would need to buy an extra cable. I'm going to instal Vista instead this weekend and hopefully that will resolve the issues. It's definitely not the drivers since I have even downloaded the beta of their latest drivers.
