MCE system reviews?
Discussion in 'Microsoft Windows' started by ngchol, Apr 19, 2005.
  1. ngchol
    ngchol
    Apr 13, 2005
    97
    +5
    I'm looking for a good roundup of currently available systems - what I'm really looking for is a mini-ITX box with integrated twin Freeview tuners. Does such a system exist at the moment? Mesh's boxes seem like good value but they make use of a single external tuner.
  2. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,269
    Build your own, much more satisfying, and you can have exactly what you want!
  3. ngchol
    ngchol
    Apr 13, 2005
    97
    +5
    great idea! I've built plenty of PCs in the past. Has anyone gone down the mini-ITX route and managed to integrate twin tuners, i.e. are there enough expansion slots?
  4. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,269
    If you can find a mini-itx mobo with twin PCI slots you are sorted, although you can get one PCI card with twin tuners on, however I don't believe this is avaiable yet for DVB-T (freeview), but I'm sure it won't be long.
    I have an MCE supported USB2 DVB-T card connected to an external powered hub which seems to be working very well, this is a good solution as you can tuck it away out of sight, and it does not drain the power supply either, I imagine you can use two, or more, although they are not cheap at £80.
  5. ngchol
    ngchol
    Apr 13, 2005
    97
    +5
    I just found this on Nebula's site - they're bringing out a dual-DVB-T device in August, and given that their MCE drivers should be ready in May, that looks like my solution :)
    http://www.nebula-electronics.com/news/onthehorizon.asp
  6. Duggy
    Duggy
    May 12, 2005
    38
    Oxford
    Tranquil PC (www.tranquilpc.co.uk) do Mini-ITX based fanless PCs with twin digital tuners. I had an earlier Via MEII1200 based model which was sluggish in the menus and slightly jerky in playback, eventually sent it back. The SP1300 model might be better, but for safety I'd go for one of their Pentium-M models.
    Cheers,
    Duggy
