MCE Stutter in Full Screen
Discussion in 'Microsoft Windows' started by whi5tler, Mar 24, 2006.
  1. whi5tler
    whi5tler
    Dec 18, 2005
    26
    Help :lease:
    I am pulling my hair out with my HTPC. It doesn't stutter in the DVB-t sofware that comes with the card and I have full signal strength. If you make a small window with the MCE TV playing it is fine but when I maxmise it I get stutter and blockyness. I had the same problem last week but when I turned Cool n Quiet off it went away. But now its back :(
    Any help would be great. :lease:
  2. Cat-7
    Cat-7
    What motherboard are you using. I had this problem with my ASUS A8N-VM and stuggle for ages until I update the BIOS to 0506. Works a treat now.
