MCE Screen Corruption
Discussion in 'Microsoft Windows' started by shaithis, Aug 9, 2005.
  1. shaithis
    shaithis
    Feb 25, 2005
    1,638
    The Last Aerie
    +30
    Been having issues with MCE causing screen corruption.
    You don't seem to have to use it long before icons and graphics that MCE has recently used start to overlay randomly on the MCE menu screens.
    ALT-TABing in and out of MCE sorts (however temporarily) it buts it is VERY annoying.
    I have tried many different drivers and BIOS values and the problem doesn't seem to get better or worse no matter what I try. The problem only happens in MCE, you never see it in a game, nor while watching TV/DVD etc (unless its playing in a Windows while navigating the MCE menu-system)
    I did a lot of searching around the net and only found one tidbit of info that states this can happen if your gfx card has less then 64MB RAM.......unfortunatly this card if a 64MB GeForce4 MX 200, which counts that particular theory out.
    Any help would be most appreciated :)
  2. lisag
    lisag
    Jul 14, 2004
    5,689
    Essex
    +335
    Your graphics card is not supported by MCE see here
    lisa
  3. shaithis
    shaithis
    Feb 25, 2005
    1,638
    The Last Aerie
    +30
    OIC :rolleyes:
    Many thanks for the extremly swift reply lisa...much appreciated again :thumbsup:
  4. Werner
    Werner
    I had the exact same problems building a very low spec mce machine for a relative, using a gf4mx440 (64mb)...very bad corruption on menu items after using mce for a few minutes, especially the guide.....menu itmes with no text in them....total lockups.....you name it, I had it.
    Every single last problem went away when I changed the graphics driver to the 66.93 revision.
  5. shaithis
    shaithis
    Feb 25, 2005
    1,638
    The Last Aerie
    +30
    Will get my freind to try that first before buying a new gfx card then.....
