MCE PC - 300GB drive - ideal partition config?
Discussion in 'Microsoft Windows' started by onefivenine, Mar 19, 2005.
  1. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    Hi folks,
    As per title I'm looking for suggestions how best to format & partition a 300GB Barracuda in a new HTPC build.
    I was considering two partitions - one 100GB for the OS install and system files - and the remainder on another single partition - for file storage.
    The HTPC will be used mainly for PVR, browsing, MS-office, games rarely.
    How have you guys got yours partitioned?
  2. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    You will only need about 10gb for the OS and program files.. you can then have the rest as one data prtition, or separate it our for different types of files, i.e. music, pictures, small videos, recorded tv and data backup = 80gb, the remainder for films?
  3. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    I'd agree with Lisag, 100gb for the OS is way too much.
  4. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    Thanks Lisa and Inzaman...
    I thought I might have been a bit off the mark - but not by a factor of 10!
    OK so if I go for a 10GB partition for the OS etc...
    Is there any real benefit - apart from faster defrags etc - from splitting the rest of the disk into other partitions?
  5. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    Its mainly one of convenience, i.e you know that all of x type files are in drive G say and all movie streams say are in drive F say.
    The only thing you have to be carefull of is getting the partition sizes correct as i am not sure if you can change these once partitioned.
  6. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    The MCE installer prompts for user partition sizes and it does the sums to end up with the 'real' storage figure - which is 286GB or so for my 300GB disk.
    Perhaps I'll go for two 135GB partitions - and a 16-ish GB (whatever's left) for the OS then...
    Thanks for your advice!
  7. mjn
    mjn
    May 24, 2001
    24,600
    Herts, England
    +13,422
    Partition Magic works on MCE?
  8. stlic
    stlic
    Feb 17, 2004
    769
    +19
    Partition magic works?!?... ;)
  9. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    We don't partition any more except to make a small restore partition to backup the orginal OS installation. This was a recommendation on the MCE training course.
  10. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    That's suprising, what happens when MCE gets all messed up and you need to format and do a clean install? Surely all the media files should be safe on a separate partition......?
  11. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    i use 5Gb for my OS thats it. then have a 2nd WinXP for games and another for linux. rest of space for data/documents/media. whats this with partition magic talk, you lot never heard of fdisk, its easy and its free and much better ;)
  12. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    Linux... there's a thought... I wanted to try it a few years ago but I couldn't run a dual-boot system for one reason or another...
    How big a partition do you think I should allocate for linux if I'm going to go dual-boot and play about with it?
  13. mjn
    mjn
    May 24, 2001
    24,600
    Herts, England
    +13,422
    Er....since when has FDISK allowed you to re-partition drives on the fly without the need to re-format and backup data?
  14. mjn
    mjn
    May 24, 2001
    24,600
    Herts, England
    +13,422
    Yeah, if you have the brains to use it.....
  15. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Parition Magic and Ghost are two 'must have' utilities IMHO. :)
    onefivenine: one other major advantage of having a small(ish) system partition is thar you can use Ghost to take an image so that when ... note I say WHEN not IF ;) ... your Windows system goes pear-shaped you can recover it from a known good state.
    Don't rely on System Restore, it doesn't always work .. for example beta versions of WMP10 couldn't be removed from the Restore Point its' installer created!
    gigtek: your MCE training just shows how little M$ understand about the problems users have keeping their Windows systems running. :rolleyes:
  16. gordonfmoore
    gordonfmoore
    First time I ever need Ghost it let me down. However I hadn't used the verify image option so I guess I only have myself to blame. It did work in cloning a harddisk though - after I had tried it four times with different options - the manual is pretty carp(sic) at providing scenarios and explanations.
    btw PCWorld seem to be doing a good offer on it at the moment £27 quid - cheaper than direct and it is the latest v9.0. Ebay has cheaper, but after buying a suspect win xp with no cert of authenticity and therefore key I'm wary now of ebay software. caveat emptor.
  17. mjn
    mjn
    May 24, 2001
    24,600
    Herts, England
    +13,422
    Ghost v9 runs in Windows only!! :eek: :eek: So no good for restoring images from floppy disk!
  18. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
  19. DaveP
    DaveP
    It spans multiple disks so it won't matter if it doesn't fit on one.
    Dave
  20. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    That's just what I wanted to hear!
    If I don't have a floppy drive - can I create a bootable CD/DVD containing a DOS version of Ghost and the drive image? I assume this would have to be Ghost 8?
  21. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    I am now sending this from my HTPC, and my C: partition is just 4.06gb, that is with Windows, MCE2005 and Program Files.
  22. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    But you boot the CD don't you? I admit I use V7, by the time V9 came out they'd bought-out Drive Image and combined the two but with DI7 you booted the CD to restore.
    You must be able to do that to restore a system partition.
    Typically about 2:1, I find.
  23. mjn
    mjn
    May 24, 2001
    24,600
    Herts, England
    +13,422
    i'm not sure, as my Ghost came with System works, so i'll have to check that
  24. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    Only other suggestion I'd make is maybe a 2gb partition for swap. I know it's not the same as having it on a different physical drive but it seems to make a difference as it's on a partition that never needs defragging....well you can defrag within the file itself but that's a different matter :)
