MCE ignores powerstrip
Discussion in 'Microsoft Windows' started by monopole, Sep 9, 2005.
  1. monopole
    monopole
    Just when I thought I had MCE running at the refresh rate I had decided upon via powerstrip using the registry hack:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Media Center
    EnableRefreshRateChange=dword:00000000
    i.e. tell MCE to use the current refresh rate
    - things get confusing.
    50Hz works fine - MCE is happy with this (I get smooth pans when watching TV and PAL DVDs). But when I changed the refresh rate to 48Hz (for inverse telecined NTSC film DVDs I have rippded to Xvid format - i.e. they run at 24 frames per second), the image judders under MCE. If I user VLC (www.videolan.org) to play the file, the image is very smooth indeed - no juddering.
    So why does MCE respect the 50Hz refresh rate, but not the 48Hz refresh rate?
    My display device is a Panasonic AE700 projector connected via DVI->HDMI. I'm using a fanless Radeon 9600XT video card.
    Most puzzling.
  2. deksawyer
    deksawyer
    May 26, 2005
    1,634
    Fife, Scotland
    +132
    do you have 'same as desktop' selected under 'display options' ---> 3D refresh rate override in the Catalyst control centre (in advanced mode)..?
    Might help.......... :confused:
    D.
  3. monopole
    monopole
    Ahhh! It was set at 60Hz (I used VNC to have a look from work).
    So how come freeview in MCE had silky smooth pans? The scrolling text on the BBC News 24 and Sky News was perfect. So was football. But if I set the desktop refresh to 60Hz, it was terrible. Very puzzling.
    Will test it when I get home tonight.
    Paul
  4. monopole
    monopole
    That setting alone did not work - I had to install reclock too (http://reclock.free.fr). Now I can switch between 48/50/60Hz via desktop icons and i always get smooth playback.
    Next challange is to get reclock to automatically set the refresh rate via the RunEvent.vbs script.
