MCE Guide timeing problem
potbelly
Help needed
The Guide has the programms 8 hours in advance. i.e. it thinks Songs of Praise is in at 10:00 in the morning. I have redone set up to no avail, any sugestions.
When I first started MCE I set the time from the desktop icon, this did not update the bios time so after next reboot the time was several hours behind (possibly 8).
I have now set the bios time correctly and MCE pick up the coorrect time from this.
Redid setup but still get the same error if I set the bios time to minus 8 hours I get the correct programs for now at the begining of the guide, reset the bios to the correct time and it thinks the programs 8 hours in the future are on now
Help needed, i.e. how to vape the guide and start again.
Using DTT and connecting to a Hitachi 42PD5700 through the DVI connection
jaymz
Although your time is correct are you in the correct time zone?
potbelly
Thank you Jaymz yhats it,
Silly me assumed when I selected UK during setup that would have been sufficient as this is suposed to be a condumer device
jaymz
No problem mate, i made that same assumption!
Podcast: TCL C815 TV, Denon & Huawei wireless speaker reviews, New Sony 4K PJ's and more
