MCE displays at 1280 * 768 !!
Discussion in 'Microsoft Windows' started by iendicott, Aug 2, 2006.
  1. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    I have a pioneer pdp436-sxe that has a native resolution of 1024*768 and my media centre PC displays at 1280 * 768, is there away to drop this size down to 1024*768 as edge of the screen is lost as the next resolution down shows a massive border around it.
    The display is an on board component output from an ASUS m2npv-vm which is a NVIDIAR GeForce 6150 + nForce 430 this board does also have a DVI-D. I have ordered up a DVI to HDMI cable, will this give me a 1 : 1 pixel mapping ?
    The bumph with the mobo says it can output 720 which is ideal but when I try running media centre it runs at 750p ????
    Thanks Ivan
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    try powerstrip
  3. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    Is this a Media Centre app or something ?
    Thanks Ivan
  4. Stiggy
    Stiggy
    Dec 7, 2004
    6,729
    Sandy Heath
    +1,049
    It's a utility you can download a trial from here.
  5. paradyne
    paradyne
    Oct 18, 2004
    37
    Buckinghamshire
    +3
    750 (750p) is 1280x720 @ 50Hz
    720 (720p) is 1280x720 @ 60Hz
    For DVD and TV playback 750p would give the best results overall
  6. robertchas
    robertchas
    Oct 2, 2004
    42
    9
    glasgow
    Keep the resolution at 1280 x 768 then use nvidia's overscan utility to shrink the screen to the required resolution this is what I do and is far more simpler than using powerstrip.
    If your screen is an hd ready screen I dont think it will work changing the resolution to 1024 x 768 as this is not an hd resolution and not what the screen will be expecting through hdmi.
    I have tried a 1 : 1 resolution on my samsung through hdmi with no luck.
    Hope this helps
    Chas
  7. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    I did see the overscan utility but wasn't to sure how this worked...
    Is there some instructions I can download on from the net.
