MCE at higher resolutions
Discussion in 'Microsoft Windows' started by davemacrae, Sep 9, 2005.
  1. davemacrae
    davemacrae
    Aug 24, 2005
    13
    I finally was at the stage to fire up MCE last night.
    I had my HTPC attached to my Phillips LCD (32PF7550D) via the DVI connection. The PC desktop was running at 1280x1024.
    As soon as I pressed the green button the screen went blank.
    If I hit <alt><tab> the desktop reappeared with MCE visible in the background but as soon as I selected it the screen went blank again.
    I reset the desktop resolution to 1024x768 and MCE appeared fine.
    Is this an issue with MCE, my graphics card (Gigabyte 6600) or something else.
    Dave
  2. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    try 1280*720
  3. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Google doesn't come up with anything when I search for the 32PF7550D, sure thats correct? I'm also guessing that the native res is 1366 x 768, if so you can set the the res to 1360 x 768 in display properties using the latest drivers, but Philips LCD TV's are notorious for not displaying full screen when connected to a PC, just search the LCD forums for more info.
  4. davemacrae
    davemacrae
    Aug 24, 2005
    13
    My mistake, should have said 32PF7520D.
    Dave
  5. davemacrae
    davemacrae
    Aug 24, 2005
    13
    Ok, issue resolved.
    I did a bit of hinting around and manual reading :)
    There is still a problem with MCE running at any resolution other than 1024x768 but that's OK now. There is a feature of the Philips that needs to be set in PC mode to swutch the TV into fullscreen instead of normal. Normal is 4:3, Fullscreen is 16x9.
    Setting this means that all the MCE stuff is shown in what I think is correct although I haven't watched much on it yet (still experimenting in the short times that the wife & kids arent't watching the TiVo).
    I've also figured out how to get the HD stuff working properly which was another concern I had.
    Thanks for the help which, while not directly useful, did point me in te right direction.
    Ta.
    Dave
