MCE and WIFI
Discussion in 'Microsoft Windows' started by evolution400, Aug 9, 2005.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Anyone use WIFI for thier Xbox extender ?
    Just wondering if MS have a minimum WIFI spec i.e will it run on B ? or is G the minimum.
  2. Skunkpipe
    Skunkpipe
    Depends what you want to stream
    In perfect conditions B is 11Mbps, given DVD can be upto 12MBps it's going to be tight. 54g (and quicker) is so cheap now anyway it would be silly not to
  3. philipb
    philipb
    Mar 6, 2002
    2,051
    63
    Swindon
    +153
    Where did you get a MCE extender from?
  4. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    I am just talking about using my xbox extender to watch TV and recorded tv etc
  5. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    sorry mate my fault I meant Xbox Extender I think they are much better value than the extenders themself.
  6. Skunkpipe
    Skunkpipe
    again depends on the quality - but saying your TV stuff is encoded at 2Mbps you should have plenty of overhead as long as your wireless is reliable.
    So in theory you should be ok, I've not done this on a 11Mbps wireless though (i'm 54g through-out)
  7. Rambles
    Rambles
    Jul 14, 2004
    8,471
    UK
    +1,352
    I spent a whole weekend trying to get this very thing to work. Wireless SuperG 108mbps, streaming from media center pc in lounge to xbox extender in the bedroom. It is an old house (1930's thick walls) and it wouldn't bloody work!
    OK for music, photos, divx, xvid - no go with tv or ripped dvd's, stuttering all over the show... I gave up sent the wireless stuff back and ran Cat5 cable upstairs instead - works perfectly every time.
    Hope you have better luck than me - or if you can run a cable, you may save yourself a lot of bother.
  8. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    It must be a different problem then, my signal is now at 60% from my MCE pc after a bit of re-jigging but still my xbox extender is unusable the only thing I have added is an RGB > SVIDEO converter from maplins could that be causing interference thats the only thing I have changed on my MCE pc in ages.
  9. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    I just remembered I updated my hauppauge PVR-350 drivers to latest march 2005 drivers I assume that these would be responsible for providing the extender with video feed so maybe thats it rollback I think just to make sure as I did this just before I installed the SVIDEO device. Sounds like a solution fingers crossed !
  10. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    I have figured out the problem is not wireless related its to do with the extender software for xbox because when I use the unofficial XBOX media center it streams divx, mpg2 flawlessly ! yet with the extender software it breaks up constantly even on the menu.
    Anyone have any ideas ?
