MCE and DScaler
fraggle
Established Member
Hi all,
Has anyone got MCE to happily run in the background, minimised, so it will record programs for me, and also had DScaler running in the foreground?
I use MCE to watch DVDs and freeview channels, but also use DScaler to watch any programs coming out from Tivo and the other two freeview boxes.
Also when MCE is taping a program I can still watch something else (from Tivo or freeview boxen)
Just that if I run MCE, quit it, and then try to run DScaler it just gives me a blank screen until I reboot?
chuckalicious
Established Member
Not sure, never tried it, but I know you don't have to have MCE running to record. If you set up a recording, then close MCe, when the recording starts, you should see a red dot in the task bar down by the clock (or at least I did). That's the program being recorded.
Maybe that helps....
fraggle
Established Member
Ta.
I didn't know it did this but shortly after posting this I had a look at what MCE had recorded and it'd recorded Lost right when I was using DScaler to watch the film on Ch5.
I'm impressed :)
fraggle
Established Member
Slinkoff said:
How do you get programs from your Tivo into your PC?
I've got a Sweetspot capture card.
DScaler processes the signal coming in to that and outputs a nice sharpened, de noised, de interlaced, scaled version to my plasma and I can also record the signal to hard disk so I could keep it or burn to DVD.
DScaler doesn't work from within MCE but they work reasonably well alongside each other. Just got to set up some remote buttons to switch between them :)
Amazon Fire TV Cube Gen 3 Review: Coming Soon
