Mce 2005 + Sky Hd
Discussion in 'Microsoft Windows' started by alfaevans, Sep 16, 2007.
  1. alfaevans
    alfaevans
    Sep 15, 2006
    121
    +5
    I'm thinking of going HD with SKY.
    I currently just have SKY Digital and MCE 2005. All works fine and no probs.
    I know I wont be able to watch SKY HD thru MCE 2005, thats not a prob. My question is ...
    Will I still be able to have the current functionality with a new SKY HD Box?
    I will only use SKY and MCE Combo to watch SD. When I want to watch HD I'll just switch and watch outside of MCE.
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Yes, you can do this. There is an s-video output on the Sky HD box. The HD channels do look better than SD even when captured via s-video. You can only watch/record on MCE whatever is the current channel displayed on the digibox so you cannot easily combine the Sky+ functions of the digibox & Media Center to e.g. record 2 channels at once or record one while watching another. It depends how big your screen is but even SD direct from the digibox via HDMI to a HDTV will be much higher picture quality than when viewed via Media Center.
  3. alfaevans
    alfaevans
    Sep 15, 2006
    121
    +5
    nigelbb,
    Thanks for the reply.
    So if I was watching a HD Channel I could still view it within MCE? (but obviously not HD) ... if this is the case then its better than I thought. As I thought maybe I'd get a tuner error or something. Then need to reboot the PC.
    As I'm not bothered about Dual tuners, I presume using MCE as I do now (to watch SD and record overnight) would be pretty much the same other than the increased PQ due to S-Video.
    For watching HD Channels changing the Input isn't much of an issue :).
    Do you have SKY HD?
    It would be pretty interesting to find out who else has something similar ... anyone?
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Yes & record it too.
    Correct.
    Yes & I use it for input to a Vista Media Center system.
  5. alfaevans
    alfaevans
    Sep 15, 2006
    121
    +5
    nigellbb,
    Looks like Sky HD is a goer :)
    Thanks for the replies.
