MCE 2005 Filter selection
Discussion in 'Microsoft Windows' started by Muf, May 14, 2005.
  1. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Anybody know how to specify the filter MCE uses to play MPEG2 video files.
    I normally use the InterVideo filter (with hardware acceleration enabled) to play my Hi Def MPEG2 recordings but I can't get MCE to use this filter. I tried increasing the merit value of the Intervideo filter without success.
    Thanks.
    Jim.
  2. lisag
    lisag
    Jul 14, 2004
    6,000
    Essex
    +398
    I think you mean dvd codec?
    You need to use an MCE compatible codec, and you can set priority using a program, that I think is called deccheck, available as a free download from Microsoft.
  3. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Thanks Lisag, I found the MS video decoder checkup utility but the problem seems to be the hardware acceleration. When I disable the hardware acceleration in the registry, the Hi Def files play much better but still not correct. I will have to look in to it further when I get time, there might be a plug in for HiDef.
    BTW is it my settings or is this sub forum upside down, the newest posts are on the last page?
    Jim.
    PS I notice the threads are right way up now.
