MCE 2005 Compatibility
Discussion in 'Microsoft Windows' started by Stellavision, Apr 22, 2005.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    Just a quick question on Media Centre 2005.
    I've read about MCE 2005 not being compatible with a lot of hardware and software, ie. Sweetspot video proccessor and FFDShow.
    Is this just on the front media end, and and will things like these work as normal in it's windows mode?
    MCE accepts ALL software/hardware in it's windows mode right?
    Just bought MCE 2005 and I'm just trying to decide whether it will be any good for me before I unwrap it.
  2. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    Anything that works in windows XP will work with the windows bit of media center.
  3. Rambles
    Rambles
    Jul 14, 2004
    8,157
    UK
    +1,132
    You can use it with ffdshow through Theatertek and My Movies...
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    Cool. Thanks.
  5. Rad
    Rad
    Jan 31, 2002
    698
    Scotland
    +4
    Which verion of ffdshow will work in MCE as I can't get any of them to work and it's a fresh install I have done.
    Or do I need to install some other component first like some c++ files ?
    Cheers,
    Rich.
  6. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    No versions of ffdshow are compatible with the MCE 2005 media front end, but all versions should work within the plain old XP desktop.
  7. Rambles
    Rambles
    Jul 14, 2004
    8,157
    UK
    +1,132
    I don't use it myself, but my understanding is that if you set up ffdshow to work automatically with Theatertek, you can then use My Movies to set Theatertek as the default player.
    So, when you play a DVD in My Movies, this will start up DVD playback in Theatertek, which will then auto kick in the ffdshow post processing.
  8. Rad
    Rad
    Jan 31, 2002
    698
    Scotland
    +4
    I was just trying to run Theatertek from the XP desktop and it wouldn't work, I've tried quite a few versions with no luck.
    which one works ??
  9. Rad
    Rad
    Jan 31, 2002
    698
    Scotland
    +4
    Got it to work now (I'd forgotten the registry change for PAL dvd's, DOH!) but it's very choppy when I resize unless I use 'simple resize' option, any ideas ??
    Also, the newer versions of FFDShow come up with green vertical bars when resizing, any idea what that is ??
    Cheers,
    Rich.
