McAfee LiveSafe 1-year subscription difference?
Discussion in 'Computer Software & Operating Systems' started by spiderman999, May 12, 2016.
  1. spiderman999
    spiderman999
    Aug 5, 2002
    475
    Isle Of Wight
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,663
    Norfolk
    +2,476
    One is a seller that has a problem with over 10% of their orders according to feedback.
    But if we compare it from a reputable store, for example £40 from Argos then it's likely the same product. McAfee have always made a business practice on making things confusing so people go for a more expensive option but a quick check suggests they don't have multiple versions of a LiveSafe subscription.
    You would get the previous year's packaging though.
  3. spiderman999
    spiderman999
    Aug 5, 2002
    475
    Isle Of Wight
    So am I getting the same product for £40.00 from Argos as I am for the £89.99 from McAfee?
