Question MCACC with a 5.0 set up.
Keiron
Apologies if you have read this question before, I placed it on the Pioneer SCLX83 thread but got no response – I guess because it’s not a current product.
Anyway, I have just acquired a Pioneer SCLX83 which has MCACC. However, I only have a 5.0 system (front pair, rear pair, centre). No sub.
However, this setup appears to not be accommodated with MCACC.
When I run the “auto” set up, it identifies that I have a sub, which I don’t.
So I have read that I should manually input the speaker setup I have, and then run MCACC. And here I get confused. There is a “Speaker System” menu, but the configurations are all preset, and there is none without a sub. Nevertheless, you have to choose one.
Then there is a “Speaker setting” menu. In here you select large, small and I do have the option to choose “No” to the sub. So I do that.
And then I run MCACC, but it still identifies that I have a sub!
Can anyone please advise?
DodgeTheViper
Long time since I've owned this receiver but, can you set your speakers to 'LARGE' you may then get the option to disable the sub ?
Keiron
Thanks. Yes I have set them to LARGE, but when you run MCACC, it still looks for a sub and apparently finds one!
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
