MC2005 Remote with WinDVD etc?
Discussion in 'Microsoft Windows' started by Doorman80, Jul 17, 2005.
  1. Doorman80
    Doorman80
    Jul 11, 2002
    84
    Hello,
    Is there anyway to get the Media centre remote to work with the likes of WinDVD & PowerDVD. I use WinDVD as my main dvd player on my media center pc as I can't get teh media centre dvd to output to the spdif.
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    what dvd decoder do you use? we may be able to fix the spdif output problem. dont know about controlling other software.
  3. Doorman80
    Doorman80
    Jul 11, 2002
    84
    Well I have AC3filter & Windvd6 installed atm.
  4. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    My Movies allows you to use Theatertek to play movies stored on your HD instead of the included Media Player 10. I know of some problems with outputting to SPDF with certain audio controllers, which audio hardware do you have?
  5. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    Have you went through the speaker setup and told it you are using the SPDIF to output to a amp, also once opened my media centre controller works PowerDVD 5 without any problems.
  6. Doorman80
    Doorman80
    Jul 11, 2002
    84
    My sounds card is just some cheap Trust ac3 sound card.
