MC-1 triggering
Discussion in 'AV Receivers & Amplifiers' started by me_too, Jul 18, 2003.
  1. me_too
    me_too
    as some of you may know i have been looking for a reciever, i have finally made up my mind and am getting a lexicon mc-1. this is now set in stone so i would rather have no comments on this for or against. however i have would rather have my query discussed. i am a little confussed about the triggering part of the beast! and the manual doesn't really give many clues can anyone shed any light on this in the way of an explaination.
    i ask as i would like to use a mains relay board, (something like this http://www.electronic-kits-and-projects.com/kit-files/3xxx/3084.pdf) to turn on and off a power supply for some active speakers. i know that the lexicon uses a 12v trigger i would just like to know if this is possible or any ideas oterwise?
    cheers
    me
  2. dunkyboy
    dunkyboy
    Jun 5, 2002
    633
    London
    +6
    Sorry to butt in but... may I ask which active speakers these might be..? :)
    Dunc
  3. me_too
    me_too
    genelec 1031's and a 7070
  4. Gary Palmer
    Gary Palmer
    Jul 17, 2000
    332
    16
    Hi me_too
    The MC-1 does indeed have a 12V trigger designed for powering up associated power amps.
    I can't see why the 12V trigger couldn't be used to power up the active speakers via some kind of mains switcher.
    It's a while since I had an MC-1 so I can't remember if it's configurable in software like the MC-8/12.
    I suggest you give Lexicon's distributor in the UK a quick call to clarify - CSE 01423 359054
    Gary
