Maybe a stupid question?
Discussion in 'AV Receivers & Amplifiers' started by bazzae123, Sep 5, 2003.
  1. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    This may be a stupid question but here goes. On the Yamaha 440RDS there are Component outputs . Now if I connect a Video recorder to the amp via a composite signal path can I then get it routed out via component?
    Bazza
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    AFAIK none of the yammy range does "video upconversion" to component video. Most of them will convert up to s-video...
  3. NicolasB
    NicolasB
    Oct 3, 2002
    6,436
    Emily's Shop
    +885
    Why would you want to? It's not going to make the picture quality any better.
  4. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    So he can have one set of cables to the TV/projector...
